How to generate next letter of alphabet?
  • October 15, 2023
  • 6 replies
  • 71 views
lazarlubomir
Forum|alt.badge.img+10
Hello everyone, is there any way how to generate next letter of alphabet? E.g I have feature with value "A" and I wanna generate next letter in alphabet, so letter "B". Is there any function for that?
Thanks a lot!
Lubo
Best answer by david_r
You can use the CharacterCodeExtractor to convert the letter to an integer value, increment the value with an ExpressionEvaluator, then convert it back to a letter using the CharacterCodeReplacer.
For reference, you're incrementing over the Unicode symbols, see https://symbl.cc/en/unicode/table/
The value below each symbol in hexadecimal, e.g. "A" = 41 hex = 65 decimal
  • October 16, 2023
nielsgerrits
Forum|alt.badge.img+64
Nice! Learned something new today :)
geomancer
Forum|alt.badge.img+60
  • October 16, 2023
Me too, I was looking into a much more complicated solution 😄
lazarlubomir
  • October 16, 2023
Great solution! I have known just NumToAlpha Converter (https://hub.safe.com/publishers/pacific-spatial-solutions/transformers/numtoalphaconverter), but Your solution is perfect for my usecase. Thank You so much @david_r​ !
hkingsbury
Forum|alt.badge.img+67
  • October 16, 2023
@david_r​ thats a really cool approach. I was about to ask how do you think you'd solve the wrap around when you get to 'Z' and you then want to have 'AA'. But thinking about it you could keep incrementing and use fmod() to figure out what the second char should be
  • October 17, 2023
To be honest I'd probably do that part in Python ;-) There are some possible starting points here: https://stackoverflow.com/questions/42176498/repeating-letters-like-excel-columns
But yes, you could probably also do it in FME combining modulo and integer division, but I suspect it would be somewhat involved unless you do it in a looping custom transformer.
