Translating from Smallworld to MicroStation using 2018 works fine but using 2020 the text is not translating correctly. I am using the same FMW file and the same Coordinate file.
  • November 2, 2022
  • 41 views
I have tried a bunch of different coordinate combinations to find one that may work. Using the one that I have always used the objects translate in the correct location, but the scaling is incorrect. Other coordinate systems the text is the correct scale but not in the correct location. I am translating from NAD27 mm to NAD27 ft. looking for an answer so we can move forward with a software upgrade. See below for coordinate info that I am using.
# KB 01/11/2013 - SRP database projection
COORDINATE_SYSTEM_DEF SRP_AZ_Central_mm               \\
 DESC_NM     "SRP Arizona Central NAD27 millemetre"  \\
 SOURCE     "SRP GIS"                 \\
 DT_NAME     NAD27                   \\
 PROJ      TM                    \\
 UNIT      MILLIMETER                \\
 PARM1      -111.9166666666667            \\
 ORG_LAT     31                    \\
 SCL_RED     0.9999                  \\
 X_OFF      152400305.0                \\
 Y_OFF      0                     \\
 MAP_SCL     1.0
# KB 01/14/2013 - SRP database projection in feet
# IFOOT = 0.3048 m (International Foot)
# FOOT = 0.30480060960121920243 m (US Survey Foot)
COORDINATE_SYSTEM_DEF SRP_AZ_Central_ft               \\
 DESC_NM     "SRP Arizona Central NAD27 feet"     \\
 SOURCE     "SRP GIS"                 \\
 DT_NAME     NAD27                   \\
 PROJ      TM                    \\
 UNIT      IFOOT                   \\
 ORG_LAT     31                    \\
 SCL_RED     0.9999                  \\
 X_OFF      500001.0                 \\
 Y_OFF      0                     \\
 MAP_SCL     1.0
f.kemminje
Forum|alt.badge.img+11
  • November 3, 2022
Please download the latest version of FME desktop, and Let us know the result.Capture2t.
  • November 14, 2022
The newest version of FME That will work with our installation of Smallworld is 2021.2.0.1 and I am still having the same issues. That being said the problem actually started with FME 2019 32 bit version, that is why we are using FME 2018 version at this time. We need to upgrade our Production Smallworld but until we can get the problem with the FME translations fixed we are stuck. I have also contacted GE and have asked for their help.
  • November 28, 2022
I worked with Dan Cooney from GE to verify that the issues with the Annotation using our current Coordinate system was not a Smallworld issue and I believe we have identified that it is not. We created 2 different ffs files one using Smallworld 5.1.6 and one using Smallworld 5.2.10. using the ffs files we tested translating to dgn using different versions of FME. 2018 32 bit, 2021 64 bit and FME(R) 2022.1.3.0 (20220928 - Build 22630 - WIN64). The 2018 version is translating correctly, both the 2021 and 2022 versions are translating the text incorrectly. Once a fix is found I will need to have it work using the FME(R) 2021.2.0.1 (20211112 - Build 21789 - WIN64) version as it is the version that is compatible with Smallworld 5.2.10. I attached files that I hope will help.
