String: select line from multi line attribute
  • September 15, 2018
  • 194 views
harmen_kampinga
Hi all,
I have a multi line string and like to do some adjustments.
For example: remove the first line of the multi line string
How do I select the first line or the first two lines?
Thanks in advance!
Best answer by takashi
Hi @HarmenKampinga, a possible way I can think of is:
  1. split the multi-line string by the newline character with the AttributeSplitter
  2. explode the resulting list with the ListExploder,
  3. filter out undesired lines with the Tester (test the "_element_index" added by the previous ListExploder),
  4. then concatenate remaining lines using the Aggregator (use the "Attributes to Concatenate" option).
Hope this helps.
Hope this helps.
harmen_kampinga
Hope this helps.
It helps indeed. Just perfect.
Now I need to create a structure, XML style. But I will sort that out.
