SQL Executor errors when using an insert into statement
  • October 15, 2019
  • 9 replies
  • 262 views
dbryantgeo
Forum|alt.badge.img+7
I have the following SQL being used by a SQL Executor;
FME_SQL_DELIMITER ;
DROP TABLE dbo.[PREMISE_CONTRACT_ROLLBACK];
SELECT * INTO dbo.[PREMISE_CONTRACT_ROLLBACK] FROM dbo.[PREMISE_CONTRACT];
It runs successfully using the "Run" option when I'm accessing the transformer itself. However, if I just add a Creator > SQL Executor > Logger and run the workbench, the following error occurs;
Microsoft SQL Server Non-Spatial Reader: Query failed, possibly due to a malformed statement.  Query Text `SELECT * INTO #fme_tempAdoDataTypeTable_spatialReader FROM ( SELECT * INTO dbo.[PREMISE_CONTRACT_ROLLBACK] FROM dbo.[PREMISE_CONTRACT] ) AS customQuery WHERE 1=0'. Provider error `(-2147217900) Incorrect syntax near the keyword 'INTO'.'
Microsoft SQL Server Non-Spatial Reader: Getting Custom SQL schema failed. Make sure all columns are named (any ambiguous columns, e.g. GEOM.STBuffer(1), must have an AS clause). If there is an ORDER BY clause, either remove it or add a TOP clause
It looks like FME is wrapping the statement in its own statement and causing the syntax issue, but I don't appear to be able to get around this.
My only thoughts right now are to add a reader and a writer, but the process is already long enough without reading unnecessary data into memory.
Best answer by erik_jan
In Oracle the Insert SQL statement is:
Insert into dbo.[PREMISE_CONTRACT_ROLLBACK] Select * FROM dbo.[PREMISE_CONTRACT].
From the documentation it seems the same in SQL Server SQL:
INSERT INTO table (column1, column2, ... ) SELECT expression1, expression2, ... FROM source_table
erik_jan
Forum|alt.badge.img+26
  • October 15, 2019
Maybe not the issue, but I think the last ; should not be there.
; is used to separate two SQL statements and none is following the last ;
  • October 16, 2019
Maybe try using a different SQL delimiter, that has worked for me previously:
FME_SQL_DELIMITER #
dbryantgeo
  • October 16, 2019
Thank you @david_r and @erik_jan. I have attempted both your proposals but unfortunately neither has worked - I'm still getting a malformed SQL error message.
  • October 16, 2019
Which version of FME are you running? The method I posted below worked fine in FME 2017.
dbryantgeo
  • October 16, 2019
Hi David, we're running 2019.1 - this is something I absolutely should've specified sorry
  • October 16, 2019
It can well be that something has changed since FME 2017, in your place I would contact Safe support about it. Perhaps also link them back to this thread.
erik_jan
  • October 16, 2019
dbryantgeo
  • October 17, 2019
How strange! At least this worked
steveatsafe
Forum|alt.badge.img+13
  • December 17, 2019
In my testing... the table was still created... and it seems the messages (similar to yours) were just warnings. Odd. I'll see if I can get this cleared up. Thanks for sharing.
