RasterExpressionEvaluator
  • November 11, 2020
  • 7 replies
  • 114 views
oliver.morris
Forum|alt.badge.img+14
Hi, I am trying to essentially take one raster over another to produce one merged raster. With some simple logic if cell is present in raster B choose raster cell B otherwise A. When I do this the transformer just outputs and empty map. what am I doing wrong? Thank you
Capture
Best answer by jdh
thanks, I tried that it didnt work either
The rasterExpressionEvaluator can be quirky if a NoData value is set. Try removing the nodata then adding it back in after the transformer.
Forum|alt.badge.img+46
  • November 11, 2020
Have you inspected the rasters going into the RasterExpressionEvaluator? Do they still look as you expect at this stage?
jdh
Forum|alt.badge.img+40
  • November 11, 2020
Try it without the @ in your conditional statement.
oliver.morris
  • November 11, 2020
oliver.morris
  • November 11, 2020
yes both look fine:
b1a1
jdh
  • November 11, 2020
  • November 12, 2020
I think @jdh has it, i can recreate. Adding RasterBandNodataSetters into a workflow before the RasterExpressionEvaluator results in an empty map (everything set to no data basically)
oliver.morris
  • November 17, 2020
apologies for the delay in replying, it has been quite a frantic few days. Removingt the nodatasetters doesnt seem to have an effect, one of the inputs has 0 already defined as no data. So I used a RasterBandNodataRemover on both data sets and now it works. Thank you @ebygomm​  and @jdh​ 234
