sql executor errors using FME 2022.2
  • February 1, 2023
  • 324 views
robotix
Forum|alt.badge.img+10
I am just starting to test out 2022.2. Using a ODBC 3.x connection with SQL executor and getting errors I have never seen before.
.....was skipped as it was not a valid SELECT statement
BADNEWS: Attribute name 'fme_type' removed from schema feature as it doesn't have a type. Current value is 'fme_no_geom'
(C:\\code\\fme\\foundation\\framework\\control\\metamap.cpp:1872) class StatusInfo *__cdecl STFMetaMapper::mapFeature(class STFFeature &,bool,bool,bool)
BADNEWS: Cannot convert null string into an integer
(C:\\code\\fme\\foundation\\framework\\util\\stf\\stfutil.cpp:347) class StatusInfo *__cdecl STF_stringToUInt(const class ObsoleteString &,unsigned int &)
... Last 2 lines repeated 40 times ...
The query still runs and I get results. The query works fine in 2021 with no problems.
The job runs multiple statements and I don't want 1000+ errors every time the job runs.
If I switch to only data features i still get the error:
... Last 2 lines repeated 3736 times ...
So what's up?
rahulsharma
  • February 1, 2023
Hi @robotix​
It appears like you have LOG_DEBUG turned on.
You can turn off the message by navigating
Go-To Tools --> FME Options --> Translation --> Log Message Filter --> Log Debug
and Uncheck the box.
robotix
  • February 10, 2023
That doesn't explain the errors. I want to know why the errors exist, not how to ignore them.
ctredinnick
Forum|alt.badge.img+20
  • February 10, 2023
Having log debug on will sometimes show errors and warnings which you can't control and which have no effect on the translation. It's best to leave it off unless the regular log messages aren't sufficient.
Maybe a solution for the "BADNEWS: Cannot convert null string into an integer" is to create the SQL statement in an AttributeCreator outside of the SQLExecutor. Is there an empty parameter which needs to be an integer?
robotix
  • February 27, 2023
Nah, tried that.
The error happens right after a row is selected and FME tries to add the result to a spatial index, even though I am using a non-spatial MSSQL connection.
FFS writer: Writing 1 feature(s) to file 'C:\\Users\\..............1 15 fo 1 RESULT 4 fc94bf7630bb5f4d8d355d9b35174e53c59dbdb3.fts'
Spatial Index: Adding 1 features
BADNEWS: Cannot convert null string into an integer........
It's just annoying to sift through a bunch of useless errors when trying to debug or tune. I wouldn't have debug logging on during normal operation.
Looks like i can avoid the "BADNEWS: Attribute name 'fme_type' removed from schema feature as it doesn't have a type. Current value is 'fme_no_geom'"
------if I change the executor to 'Data Features' only.
That removed about 3/4ths of the errors.
Not sure why FME all of a sudden assumes there is supposed to be an fme_type attribute...
