EsriPropertyType="PictureX"
  • October 28, 2021
  • 7 replies
  • 59 views
itay
Forum|alt.badge.img+18
Does anybody have any experience writing GDB metadata images into SDE?
I can update just about anything but inserting an image to the item description needs to be in a specific ESRI binary format (EsriPropertyType="PictureX") and the AttributeFileReader transformer does not support this encoding type.
Cheers,
Itay
Best answer by david_r
Have you tried converting the binary image file (jpg, probably) contents to Base64 with the BinaryEncoder?
Not tested, but inspired by the following code found on an Esri forum post.
import xml.etree.ElementTree as ET
import base64
with open(jpgFile, "rb") as img_file:
  strEncoded = base64.b64encode(img_file.read()) # Create the needed thumbnail xml element
  attrib = {'EsriPropertyType':'PictureX'}
  subEl = ET.SubElement(root,'Binary')
  subEl = ET.SubElement(subEl,'Thumbnail')
  subEl = ET.SubElement(subEl,'Data', attrib)
  subEl.text = strEncoded
  • October 28, 2021
import base64
itay
  • October 28, 2021
import base64
Hi @david_r​ ,
Thanks for the tip, unfortunatly the BinaryEncoder does 'something' but the image is not displayed correctly in AcrCatalog:
imageand using python is not an option.
  • October 28, 2021
Hi @david_r​ ,
The Python code was mostly to show the context.
Are you able to fix the thumbnail in ArcCatalog and export the XML as a template? How does that compare to what you're generating?
itay
  • November 1, 2021
Hi @david_r​ ,
Hi @david_r​ ,
I have done some more investigating and managed to insert the image correctly into the SDE metadata as opposed to previous attempts of replacing the image.
afod
  • April 21, 2022
Hi @david_r​ ,
Hi itay,
I am trying to do the same thing, do you have any information on how you achieved it?
Thanks, :)
itay
  • May 10, 2022
Hi @david_r​ ,
As mentioned converting the image into base64 with the BinaryEncoder.
afod
  • May 10, 2022
Hi @david_r​ ,
Hmm ok, I've tried that and my blob comes out exactly the same as before no matter what I do. Was there anything else I might be missing?
Update: Just figured it out :) thanks!!
