I am looking for suggestions on how to create Response Areas based on a Road Network and Station Points.
  • September 26, 2022
  • 6 replies
  • 47 views
juliarozema
Forum|alt.badge.img+10
For example:
DATA INPUTS:
1) Greater Geographic Region Polygon - basically the greater region of interest.
2) Road Network within Geographic Region - network has topology, along with speed and time cost attributes.
3) Station locations - they may or may not fall exactly on the network.
How can FME take the Greater Geographic Region and split it into sub regions; one region for each station based on the drive times out from the station. The result is a Station Response Area.
DanAtSafe
Forum|alt.badge.img+22
DanAtSafe
juliarozema
Thank you Dan. At the bottom of this page with in "NOTES" it says "Create a model including ALL points (for example all firehalls). ... See this workspace for an example". The link for "this workspace" seems to be missing. Do you know of an example of how to use the GroupBy within NetworkCostCalculator?
DanAtSafe
Hi @juliarozema​ Thanks for pointing that out. You want to try nearestfirehall which does have a GroupBy set in the NetworkCostCalculator.
juliarozema
  • September 28, 2022
I need a bit more help with this. Is there a way to do a screen share session with yourself or another safer who is familiar with this type of process?
juliarozema
Maybe I should tag you in my reply :)
@danatsafe​
