convert line to an arraw
  • June 7, 2017
  • 65 views
Dear All ,
We have a line and we need to add an arrow to it , as shown below we need to add the blue line , it looks that we need to use 2d pointer adder but how to get the exact location from the end point and draw two lines
Best answer by takashi
Hi @khalid_omer, just an idea.
  • June 7, 2017
Great @takashi works like a charm
Just a quick note to say - really useful! We use ArcGIS enterprise portal to publish our data & apps and it won't style lines with arrows to show that stock has to go from one location to another. Works in Pro, but won't publish to Portal. So had to get creative, and this little workflow is the answer to get lines published in a way you can style in portal. Thanks
fme_hans
Forum|alt.badge.img+5
  • August 2, 2022
How to create "arrows" which all have the same size? With the above the size of the arrows is different for each arrow.
