I have two datasets of a road transportation network (comprising of line segments). The first dataset is say from 2012 and the second from 2013.
I want to detect changes in both datasets, i.e. to identify:
- which roads were completely new build in 2013,
- which roads had their designation changed (e.g.: from A1 to B95) and
- which roads were destroyed in 2013 (rarely happening, but can be the case)
The problem is to identify road segment that have been changed partially, say were a designation changed but the geometry keeps the same. Is the ChangeDetector the suitable transformer to solve this?
Many thanks.
Kind regards
Thomas
