Is it possible to create an AutoCAD 3D soild with different coloured surfaces
  • August 12, 2019
  • 15 replies
  • 138 views
virtualcitymatt
Forum|alt.badge.img+47
I've been having some issues with Creating and reading AutoCAD 3D Solid geometries.
Through my investigation I have found that the REALDWG writer/reader supports solids the best (ACAD will just read as multi-surface in most cases), however, when it comes to colours/appearances FME is falling short.
While I can create a single solid feature with once color (using the default layer color), I am unable to color the surfaces individually which is pretty well supported by a lot of other formats in FME.
In addition DWG files which contain solids which have different color surfaces are just read in with all surfaces coloured as the layer color.
Has anyone had any luck either creating OR reading solids from AutoCAD witch have different colored surfaces?
Here's an example which creates a multi-colored solid box:
@daveatsafe or @andreaatsafe perhaps there are some PR's relating to these issues already?
Best answer by jovitaatsafe
Hi folks!
I'm pleased to announce an update regarding (FMEENGINE-61199).
Writing different coloured faces from Brep solids should now work for the AutoCAD writer but the caveat is that the RealDWG writer isn’t able to output solids with different appearances per face like this just yet.
You can find the fix in the latest beta from our downloads page.
sigtill
Forum|alt.badge.img+25
  • September 4, 2019
output_box.dwgAdd GeometryCoercer to fme_composite_surface.
I`ll leave for the end-user to figure out why it works :) (or Dr Geometry @daveatsafe )
virtualcitymatt
Right - indeed it does, however, in this case the output is not a solid but 6 different mesh geometries which isn't quite what we're wanting here
sigtill
  • September 4, 2019
Do you have an example DWG that is correct? Or can you create this file in AutoCAD and then upload it here? @virtualcitymatt - a box is nice.
gio
Forum|alt.badge.img+15
  • September 4, 2019
@virtualcitymatt
Hi, This is how you can do it.
After styling, use a setter to set the style. Solidbuilder to make it a solid.
Both (dwg as well as the ds) have correct solids with multicolor.
29249-boxtocoloredbox_ok.fmwt
sigtill
  • September 4, 2019
@virtualcitymatt
Seems to still be only one color though?
virtualcitymatt
Yeah exactly - I think being able to style solids in this way is fairly new in AutoCAD which is why I assume that it doesn't yet work in FME.
virtualcitymatt
No, sadly no test data I can share and I don't have AutoCAD to create any doh!...I was trying to use FME to create a autocad solid with multicolored surfaces to send to Safe to show that their reader didn't read the colors properly but I wasn't able to create one...because of this issue. heh.
gio
  • September 5, 2019
@sigtill
@virtualcitymatt
Check the autocad site or fora.
Ability to color individual facets of a solid is pretty old. (at least since 2106 it is in autocad. I hav no older versions available to check..)
Try enter on the command line in Autocad: -TOOLBAR and then enter solid_editing
There is a specific command to color indidual face called.."Color faces" ..who would've guessed!
I did one and saved it. Opening in FME shows no coloration. No parameters or anything.
As is visa versa, as @sigtill noticed.
So it is indeed the fme writer that does not treat it correctly if at all.
Maybe, if there is sufficient demand for it, safe will?
(as D.T. says "maybe they will, maybe they won't. Who knows.)
I htink to do it using fme would be to write a lisp and start it using a bat file through the systemcaller
virtualcitymatt
@sigtill
@virtualcitymatt
Thanks for the extra info @gio, Helpful to have it checked! Hopefully safe add this into AutoCAD readers.
gio
  • September 5, 2019
@sigtill
@virtualcitymatt
strangely, i managed to get the dwg to show mulitcolor y-day. But fail to do now..which baffles me a bit.
andreaatsafe
  • September 10, 2019
Just a quick note to say we've filed a problem report for our development team to look into this (internal reference number: FMEENGINE-61199).
We'll update when there is a resolution to this.
Thanks!
- Andrea
virtualcitymatt
Thanks!
- Andrea
Awesome! Thanks Andrea!
jovitaatsafe
Forum|alt.badge.img+11
  • June 23, 2020
Hi folks!
virtualcitymatt
Hi folks!
Awesome, Thanks for the update I'll need to test it out!
kennyo
Forum|alt.badge.img+26
  • June 29, 2020
Hi folks!
Perfect, I will test it shortly.
