What could be the issue here. `MapnikRasterizer` is giving an error!
MapnikRasterizer(MapnikFactory): Performing rasterization...
MapnikRasterizer(MapnikFactory): Failed to rasterize data. The error was: bad allocation
MapnikRasterizer(MapnikFactory): A fatal error has occurred. Check the logfile above for details
Here is FME file:
https://drive.google.com/file/d/0BwMirpbclFbrLUF6d...
