issue with converting points to polygon
  • July 5, 2017
  • 25 replies
  • 108 views
Hi There, I have a set of points that make up an area of interest. I am trying to create a polygon using the points, using Linebuilder & LineCloser. It does create the polygon but it's not what I was expecting. I am looking for some feedback on how to resolve this. Thanks Jay
erik_jan
Forum|alt.badge.img+26
  • July 5, 2017
I would create the polygon using a HullAccumulator
erik_jan
  • July 5, 2017
Or if they are all rectangles, the BoundingBoxAcculmulator is also an option. Use the Group by option to create rectangles per grouping attribute.
  • July 5, 2017
Thanks Erik for your quick feedback. Using HullAccumulator with Concave option, I get this. It's better than what i had before, tried few alpha values but still not getting clean edge.
With Bounding Box Accumulator, it creates a bounding box that covers all the polygons, this wotn work in this case.
Thanks
  • July 6, 2017
The important thing to note about the LineBuilder is that it'll construct the line in the exact order that it receives the points. For this reason, you'll probably want to use something like a Sorter before the LineBuilder to make sure your point features are in the order that you want your polygon vertices.
  • July 12, 2017
Thanks for the note. I tried BoundingBoxAccumulator and this is what I get, it's giving me some extra area in SW corner, where there are no points. Jay
erik_jan
  • July 12, 2017
Do the points that should form a polygon have a defining attribute to group by?
Because grouping should get you the 4 areas and not one single area for all points.
  • July 12, 2017
I am using group by option. Thanks
erik_jan
  • July 12, 2017
I have created an example showing what I mean.
It is creating a set of points (I tried to place them in the workspace at the location the points are created) and then generates the polygons.
Hope this helps.bbox-example.fmw
  • July 12, 2017
Thanks Eric for the example workspace. This workspace creates the output correctly. I noticed that your group by fields are different (ID; 1,2,3). In my case, I have the same id for all the points. This is why I am not getting the result that i am expecting because Bounding Box Accumulator expects the values to be different. Some additional background, I started from three different polygons with same attribute, extracted all the vertices and then I want to create a polygon that combines all the points. The way I interpreted that group by would combine all the points with the same attribute into one geometry but this is not the case here.
erik_jan
  • July 12, 2017
The Group By groups all features with same value for the selected attribute.
Before creating the vertices from the original polygons, you could add a dummy attribute by using a Counter transformer and the use that to Group by.
Hope this will give you ideas how to move forward.
  • July 12, 2017
Thanks, I will try to get data prepared for this and see how that goes. Appreciate your help. Jay
  • July 13, 2017
I'm just curious. Since you started from three different polygons, you must have the polygons originally. Then, why do you need to recreate the polygons from the points?
  • July 13, 2017
Perhaps are you going to resolve small gaps between the original rectangular polygons and merge them to form a single polygon? If so, a combination of the Snapper (Snapping Type: Segment Snapping) and the Dissolver could be an easier workaround, rather than building an area from points.
  • July 13, 2017
Hello Takashi, Thanks for your input. You are right, I am starting with polygons and then trying to merge these to create a combined geometry that is made up of all the polygons. Our existing workspace does use snapping/dissolving to do this. It works fine mostly but we came across an issue where workspace misses some of the polygons. The odd thing about this is that if I run FME process with smaller dataset it works fine but when running with full dataset, it misses polygons. I have an active case with FME support on this issue and have provided them with recordings.
In the meantime, I am looking to find alternative approaches for solving this problem. I converted polygon vertices to points and then hoping to build polygon from there. I came across HullAccumlator transformer that seemed promising but transformer all points to be in sequence to work properly, which isn’t the case as each individual polygon has its own orientation. This is what I get.
I am trying to see if Bounding Box Accumulator can provide what I am looking for.
Thanks
  • July 14, 2017
Thanks
I've understood the situation, but I think it could be quicker to investigate the reason that some polygons have been missing when you applied Snapper + Dissolver and think of a way to avoid that. Can you share a minimal dataset containing polygons that reproduce the symptom (i.e. some polygons would be missing after applying Snapper and Dissolver)?
pratap
Forum|alt.badge.img+12
  • July 14, 2017
Is it possible to post the data to give a try...
pratap
  • July 15, 2017
I assumed input is polygon. You are converting polygon to point and joining all the points back to become polygon. So I have prepared the workbench based on this logic. Hope this helps...
none2none.fmw
  • July 16, 2017
This workflow could also be a workaround in the interim. Assume the input geometries are rectangle polygons adjacent together and there could be a small gap between them.
  • July 19, 2017
Thanks Pratap, Here is the actual data set for my testcase. Jay
test.zip
  • July 19, 2017
none2none.fmw
Thanks Pratap for sharing this, I did try and replace the input from my test case in this workspace, it does create polygons but still keeps inside polygons boundaries. Jay
  • July 19, 2017
The right orange shape is a single polygon which is created from your sample data with the workflow above. Is this your desired result?
result
  • July 19, 2017
Hi Takashi, This is exactly what I am looking for. Do you mind sharing this workspace? I would like to try few other cases. I really appreciate your input on this. Thanks Jay
  • July 19, 2017
This is it: dissolve-disjoint-rectangle-polygons.fmwt (FME 2017.0)
pratap
  • July 20, 2017
I have removed the creators and added the input data you have provided. I have attached the results to this thread. I did not find any contradictions.
What do you mean by "but still keeps inside polygons boundaries"???
  • July 26, 2017
Thanks Takashi, The result from this workspace are very promising, I am still in process of checking few more cases that are complex /disjointed geometries. Thanks for your help on this. Jay
