Hello,
How can I remove all blank lines from an attribute values.
Blank lines are as shown in next screenshots
Thank you very much.
Hello,
Have you tried the AttributeTrimmer?
If you do not specify a trim character, white space is removed (spaces, tabs, newlines, and carriage returns).
I have tried it but didn't get the desired result
I wanna keep spaces but remove only blank lines
Click the button to the right of the "Trim Characters" setting and open the the text editor.
Insert a blank newline and close.
That works for me, anyway.
Thank you !
