Data shattering leading to error running translation
  • January 23, 2020
  • 37 views
Hi all,
I'm a newcomer to FME from the geospatial side of things and have inherited a somewhat large model of complex geometric operations (clips, intersects, bounding boxes etc...). On trying to run the model (with data and a workbench that has, supposedly, succeeded in 2018) I always encounter this "data shattering" warning leading to a fatal error.
Hit data-shattering case as 55 new nodes were created after phase 7, compared to 2 nodes created after phase 1
To resolve the above issue, try setting a tolerance if your transformer has a Tolerance parameter
Error running translation
I believe I've narrowed the problem down to a NeighborFinder operator, and have attached screenshots of the processes leading into it, as well as its parameters.
From this prior answer, and linked blog post, it seems that "data shattering" relates to problems of over accuracy, so to speak (?). Though, from from my (limited) understanding, there were no answers to my question there, hence my question here.
Ideally solutions that don't require too much tampering with the wider model would be best, though I recognise this may not be likely!
Other bits of info that may (or may not) be useful:
FME(R) 2019.2.2.0 (20200103 - Build 19817 - WIN64)
Windows 10
i7-7700K
64 GB RAM
Back end of the log is also attached.
Any help would be much appreciated!
  • January 23, 2020
@ephor It's possible we have introduced a regression into FME 2019. Try running the workspace again using FME 2018. You can have multiple installs of FME Desktop on the same computer - just use a different install folder. You can get previous versions of FME here. If this works, then you'll probably need support help from your FME provider to dig into this a bit deeper.
  • January 28, 2020
Just to update, your suggestion of reverting to FME 2018 worked and the workbench completed without issue.
Many thanks for your help!
