Find unique (non-duplicate) geometry with no textures
  • September 25, 2018
  • 27 views
Hi, I am parsing a 3D CityGML model that mostly have a texture for each IFMEFace. That is great, but sometimes there are duplicate IFMEFaces, one with texture and another without, which I can filter out those untextured ones using GeometryPropertyExtractor. But other times, there are untextured IFMEFace with no duplicates that I still like to keep, which the GeometryPropertyExtractor filters out regardless. How can I achieve this?
I tried the Matcher but I think I just want either the SingleMatched or NotMatched output, not both.
Thanks for any help.
My current setup:
Best answer by daveatsafe
Hi @meancat,
Please run the faces through the Matcher first, then remove the Matched Faces with no texture. Keep all the faces from the NotMatched port.
Don't use the SingleMatched output, the data from this is a modified duplicate of the Matched output.
daveatsafe
Forum|alt.badge.img+20
Hi @meancat,
  • September 26, 2018
Hi @meancat,
That's it! Thank you!
