Calculate difference in hours between two strings
  • November 5, 2018
  • 20 replies
  • 435 views
I have two string fields (TimeStartedCTZone, TimeEndedCTZone) formatted as shown below. How can I calculate the difference in Hours despite having strings as inputs instead of datetime data types?
Best answer by lenaatsafe
Hi @mariofederis
DateTimeCalculator accepts datetime values in FME format only. I.e., before you attempt to calculate intervals, you need to alter your values format using DateTimeConverter.
  • November 5, 2018
The posted link to the screenshot is broken, but generally speaking this is the way to do it:
  1. Convert both fields to the FME datetime format using the DateTimeConverter transformer
  2. Use the DateTimeCalculator (Mode = Calculate interval) to calculate the difference
Looks like the data input into the DateTimeConverter are being rejected. Unsure why. Probably because it's a string.
  • November 5, 2018
That typically indicates that FME cannot automatically infer the input datetime format and that you have to explicitely specify it in the DateTimeConverter.
chrisatsafe
  • November 5, 2018
Hi @mariofederis,
Another way to do this is inside the AttributeManger using Date/Time Functions. Set the value of the Duration attribute to the following expression:
@DateTimeDiff(@Value(TimeEndedCTZone),@Value(TimeStartedCTZone),hours)
Next, you will have to reformat your date string attributes (TimeEndedCTZone and TimeStartedCTZone) using a DateTimeConverter, you will want to use the following output format:
%d/%m/%y %H:%M %p
Hope this helps.
- Chris
Difference_in_Hours.fmwt
Hi @mariofederis,
%d/%m/%y %H:%M %p
Hope this helps.
- Chris
Chris, I tried the attribute manager with said expression previously but received the following mesage: 'AttributeManager: Failed to parse '01/11/18 5:00 AM' as a datetime value. Not sure what I'm missing.
It also appears the input in your example is a datetime data type instead of string
I tried specifying the input format but no luck. Still being rejected.
chrisatsafe
  • November 5, 2018
Have you tried setting the Type to datetime for the TimeStartedCTZone and TimeEndedCTZone in the reader feature type parameters?
You can do this by going to Readers > Update Feature Types or by right-clicking the reader feature type in the Navigator pane.
Hi @mariofederis,
%d/%m/%y %H:%M %p
Hope this helps.
- Chris
Perhaps I should have explained further. TimeStartedCTZone and TimeEndedCTZone are actually created fields within an Attribute Manager (see below).
They are created from the following expression in a text editor: @DateTimeFormat(@Value(dateStarted),%m/%d/%y) @DateTimeFormat(@Format(%04d00,@Value(timeStarted)),%l:%M %p)
Unfortunately, these two attributes are not in the feature reader, but instead, created in the translation. Hence, I cannot change their types. Or I'm unsure how.
  • November 5, 2018
Two reasons:
  • %Y refers to a 4-digit year, yours seems to have only two digits
  • %H refers to a two-digit 24 hour clock, your timestamp seems to use 1 or 2 digits and AM/PM notation
Try the following in the DateTimeConverter:
%d/%m/%Y %l:%M %p
Which will let us discover a weakness in the DateTimeConverter, since it doesn't seem to handle two-digit years in the input mask, for some weird reason.
I fixed this by using a StringReplacer first to add "20" to the year:
But since you're creating the timestamps yourself in the AttributeManager, you'll probably be much better off by "fixing" the timestamp there.
Two reasons:
%d/%m/%Y %l:%M %p
David, I went ahead and changed the format of TimeStartedCTZone and TimeEndedCTZone to include a 4 digit year using %Y.
But when I add the recommended DateTimeCalculator, it looks like the inputs are rejected with the following message:
fme_expression_warnings{0}.message (string): Failed to evaluate expression '@DateTimeDiff(01/11/2018 7:22 AM,01/11/2018 5:52 AM,hours)'.  Result is set to null
These were my settings:
chrisatsafe
  • November 5, 2018
@mariofederis - try using the StringSearcher to extract the time from the string and save that to a new attribute. Then, convert the time to the FME output format before passing it into the DateTimeCalculator. You will need to set the Input format to
%H:%M
Then, you can calculate the time difference (Duration) using the DateTimeCaluclator with the StartTime and EndTime attributes that were created in the StringSearcher.
Difference_in_Hours_String_Search.fmwt
%H:%M
I attempted the recommended setup, but features are still being rejected.
I also tried the workspace provided with the same result. I received the following message: 'fme_expression_warnings{0}.message (string): Failed to evaluate expression '@DateTimeDiff(7:22,5:52,HOURS)'.  Result is set to null'
  • November 5, 2018
Hi @mariofederis
  • November 5, 2018
Hi @mariofederis
  • November 5, 2018
Two reasons:
%d/%m/%Y %l:%M %p
Hi @david_r
We made decision not to support two digit year for parsing... at least for now. There are several different standards (I like the Excel approach: https://support.microsoft.com/en-ca/help/214391/how-excel-works-with-two-digit-year-numbers - it is versatile and confusing at the same time). As FME is used by users familiar with different formats/tools/standards, we wouldn't be able to find an option good for all. To avoid confusion and data misinterpretation, we delegated setting up the two year interpretation rules to those who know their data best.
This might change in the future. We might be able to implement some kind of WB setting or workspace parameter that will control two digit year interpretation or introduce a cutoff year. We will rely on users' input/feedback while making this decision.
chrisatsafe
  • November 5, 2018
If possible, are you able to upload your workspace and sample data? You can use an AttributeRemover to remove any irrelevant/sensitive data and write it out to the same format as the source dataset or as an FFS. The only attributes required are the dates used to create the TimeEndedCTZone and TimeStartedCTZone attributes.
  • November 5, 2018
Hi @mariofederis
@LenaAtSafe is right.
From your description above, the "dateStarted" seems to be formatted in %Y%m%d (standard FME date format), and the "timeStarted" seems to be formatted in %k%M. If so, you can convert them into standard FME date/time format (%Y%m%d%H%M%S) with this expression.
@Value(dateStarted)@Format(%04d00,@Value(timeStarted))
  • November 6, 2018
Hi @david_r
Hi Lena, thanks for the explanation!
  • November 6, 2018
Based on the error message it seems the timestamps weren't properly formatted by the DateTimeConverter first?
Thanks everyone. I ended up converting TimeStartedCTZone and TimeEndedCTZone into FME format within attribute manager before using the Datetimediff function. This eventually produced the correct result (duration)
