DateTime Calculator Error on FME Cloud
  • November 19, 2019
  • 20 views
I am trying to calculate time difference (in minutes) between two values using the DateTimeCalculator. Both are in the format %Y%m%d%H%M%S and have been run through the DateTimeConverter.
The workbench completes when run on FME Desktop but when i upload and try and run on FME Cloud im getting the following error.
mark2atsafe
Forum|alt.badge.img+59
  • November 19, 2019
The first question would be, are the two FMEs (Desktop and Server) the same build number? Or at least the same version of FME?
mark2atsafe
  • November 19, 2019
I'm suspecting that the Desktop is newer than Server.
  • November 29, 2019
Yes thats fixed it @mark2atsafe, have upgraded our cloud instance to match the desktop version.
