Create Geometry from XML (GML)
  • March 21, 2019
  • 6 replies
  • 309 views
pflegpet
Forum|alt.badge.img+8
I am trying to create geometry from a coordinate list in GML but it does not work with the GeometryReplacer (GML). I don't know if I did anything wrong with exposing the XML attribute containing the geo or if the format is the problem.
The following template contains the workspace and the XML source. The coordinates are stored in the XML tag "Building.geometry2D.BuildingGeometry2D.geometry.Polygon.exterior.LinearRing.posList
Thanks in advance for any help!
Best answer by itay
Hi @kasparlov,
Use the xml_fragment attribute in the GeometryReplacer, this will work like a charm.
Itay
itay
Forum|alt.badge.img+18
  • March 21, 2019
Hi @kasparlov,
Itay
pflegpet
  • March 22, 2019
Hi @kasparlov,
Itay
It does work but the xml_fragment only contains one point coordinate. I want to create polygon features from the "....posList" attribute that contains multiple coordinates.
Forum|alt.badge.img+46
  • March 22, 2019
There doesn't appear to be any polygon geometry within your xml, only points...
nielsgerrits
Forum|alt.badge.img+64
What @itay describes works very well, just use a GeometryFilter to split the points from the areas, as they are hard to find.
pflegpet
  • March 22, 2019
Thank you, that works beautifully!
gio
Forum|alt.badge.img+15
  • March 22, 2019
@kasparlov
The member file wich is 564087.xml. Is zipped with fonts.
The canvas does not recognise it as a gml, which it is.
If you pull out the 564087.xml and put it on the canvas and choose gml, you get the geometry.
No geometryreplacer or anything needed.
