XML accessing attributes at parent level
Hi All XML Format as follows: <?xml version="1.0" encoding="UTF-8"?> <Flows><SCN> <SystemCodeNumber>N11111J</SystemCodeNumber> <FlowType>Scoot</FlowType> <ShortDescription/> <Northing>0.00</Northing> <Easting>0.00</Easting> <Flows> <Flow Date="2015-05-03 05:08:35">1.0</Flow> <Flow Date="2015-05-03 05:13:35">4.0</Flow> etc. I am accessing an XML file as a single merged feature type as i would like an output as follows: SystemCodeNumber,Northing,Easting,Speed,Flow,Date N11111J,0.00,0.00,,1.0,2015-05-03 05:08:35 N11111J,0.00,0.00,,4.0,2015-05-03 05:13:35 N11111J,0.00,0.00,,1.0,2015-05-03 05:18:35 N11111J,0.00,0.00,,0.0,2015-05-03 05:23:35 as so on. I am getting the elements i want:
and flattening the elements: not the output is fine, im getting what i require out: I have my SystemCodeNumber, Easting and Northing out. I would like to add them as i one to many so i can get my output as required. At the moment im testing to see if the attribute exists and storing it in a VariableSetter and Retrieving it before writing. What im trying to figure out (without having to go down the python route as i can do it in python is if we have a simpler way to do this? Thanks
Best answer by takashi
Hi, try setting "SCN" to the Elements to Match parameter. Values of the attribute "Flows/Flow/@Date" will be stored in a list attribute called "Flows.Flow{}.Date". You can then explode features on "Flows.Flow{}" with the ListExploder. However, I'm not sure how the "Speed" should be treated, since "Speed" elements are not shown in your sample XML doc. Takashi
  • November 25, 2015
  • November 25, 2015
Hi Takashi. Apologies, the Speed element gets added in a FeatureMerger later in the workbench.
I will give your advice a go and let you know, thanks for your reply.
  • November 25, 2015
OK. In addition, to improve performance, it's better to remove unnecessary attributes before exploding.
  • November 25, 2015
Hi I have done the following:
And this is the output. I have lost the list but thats not an issue. I would like the fields that have attributes from SystemCodeNumber, Easting, Northing to replicate to all the rows ie 1toM?
  • November 25, 2015
looks okay but the issue is with replicating the SCN,X,Y, into all rows?
  • November 25, 2015
This is my settings and the result from your sample XML. Isn't the resulting table your desired one?
