Geometry error in Arcmap
  • May 7, 2018
  • 5 replies
  • 15 views
f.kemminje
Forum|alt.badge.img+11
Hi Team
I created the complex polygon from utility map(buffered the line geometries and dissolved the buffered polygon). I am able to write to oracle spatial table. able to open in fme viewer. But when i consume this table in arcmap it gives geometry error msg saying that "one or more layers failed to draw".
and not rendering in arcmap. the polygon looks like the image in the attachment.
Please help.
fmelizard
Forum|alt.badge.img+21
  • May 7, 2018
Hi @fkemminje Do any of the inner shells touch (intersect) the outer shell?
f.kemminje
  • May 8, 2018
@DanAtSafe
May be, I dont know.
if it is there how to repair it?
fmelizard
  • May 8, 2018
@DanAtSafe
@fkemminje Test with a GeometryValidator, or split the shells apart with a DonutHoleExtractor and pass those into an Intersector.
f.kemminje
  • May 9, 2018
But Dan I am finding different types of problems
self intersectors
many points within tolerance
redundant points
etc..
I want to fix all the geometry errors
fmelizard
  • May 9, 2018
self intersectors
redundant points
etc..
Hi @fkemminje You should be able tor repair with the GeometryValidator as well. Try FME 2018.1 beta if possible https://www.safe.com/support/support-resources/fme-downloads/beta/ The GeometryValidator can now remove duplicate vertices within a tolerance.
