create new features within a python caller
  • February 21, 2017
  • 7 replies
  • 1209 views
Every exemple of python caller I see would only modify attributes or add new attributes to each input feature. Is it possible to output new features or more features than were received by duplicating some inputs ?
Best answer by jeroenstiers
Hi @vchalmel
Yes, that is possible indeed. The code below allows you to create a new feature.
You can output this feature by using the second line of the sample.
newFeature = fmeobjects.FMEFeature()
self.pyoutput(newFeature)
This code only works when using the object-implementation (so not the function-implementation) of a PythonCaller. In the function-implementation, the feature entering the PythonCaller is outputted automatically.
Forum|alt.badge.img+7
  • February 21, 2017
Hi @vchalmel
  • February 21, 2017
Sure, as long as you use the class template it's pretty easy. Here's an example that outputs 10 features for every incoming feature, including a new attribute "item_no" (which you'll have to manually expose in the PythonCaller)
import fmeobjects
class Multiply(object):
    def input(self,feature):
        for n in range(10):
            new_feature = feature.clone()
            new_feature.setAttribute('item_no', n)
            self.pyoutput(new_feature)
You can also use the PythonCreator to this effect, although the usage is slightly different (there's a nice example in the documentation).
itay
Forum|alt.badge.img+18
  • February 21, 2017
Why not use the Cloner?
  • February 21, 2017
Hi @vchalmel
OK, so pythonCreator and pythonCaller share every python function of the python FME library.
  • February 21, 2017
import fmeobjects
        for n in range(10):
That's precisely because pythonCreator receives no input that i was puzzled about pythonCaller ability to use fmeobjects.FMEFeature()
  • February 21, 2017
Exactly, that is the difference
  • the PythonCaller gets called once for every incoming feature and outputs n features
  • the PythonCreater is called once when the workspace starts and outputs n features
  • February 21, 2017
Yes, the fmeobjects Python API is shared by all the FME components that use Python.
The documentation is extremely handy: http://docs.safe.com/fme/html/FME_Objects_Python_API/index.html
