with DGN file i have points and line strings with outer boundary polygon and how to make polygon with points and polygon
  • October 24, 2019
  • 25 views
srg
Forum|alt.badge.img+10
  • October 25, 2019
@pranneshgeo, you will need to try out the LineBuilder to first build lines from the points and then AreaBuilder transformer for making polygons. The AreaBuilder takes a set of topologically connected linework and creates topologically correct polygon features where the linework forms closed shapes.
HTH
Happy FME-ing :-)
SRG
gio
Forum|alt.badge.img+15
  • October 25, 2019
@pranneshgeo
Hi.
1. Select all lines (tester)
2. Linebuilder, grouped by Class (I'm assuming different colors are different objectclasses) If not, group them by color.
3 Use a Intersector or a LineOnLine Overlayer . (LineOnLineOverlayer has tolerance option, you might want that if the drawing is topologically not perfect).
If topology still not ok, use 1 snapper "endpoint" maode and (maybe) 1 snapper in "segment" mode.
4.Areabuilder.
5. Relate the points to area using a SpatialRElator where area contains point. This way you can transfer the point info to the area.
If you need example, post the (sample) data you display in the image.
