Transposing attributes like Excel does
  • April 11, 2016
  • 5 replies
  • 22 views
femo
Hello,
I am reading a folder containing various Excel files of the same schema. The difference between the files is the date and the content, the structure is always the same. My goal is to create a line diagram in a new Excel file. I want to use the "ChartGenerator".
My Problem now is to prepare the data to be used within the ChartGenerator:
I will have a bunch of records as illustrated in the "Start" section of the above pic. For every additional date I will have an additional record. I need to convert the data as illustrated in the "End" section. For every additional date I will need an additional column.
The various existing Posts regarding transposing data do not seem to tackle my issue.
Any ideas?
  • April 11, 2016
Hi
Have you looked at the AttributePivoter?
David
gio
Forum|alt.badge.img+15
  • April 11, 2016
There are a lot of posts on the forum showing soltuions.
Pivoter is ..usable
You still have to expose the attributes.
Best use a attribute exploder, remove fme-attributes, expose xls_row id.
Create a csv or txt-file.
Examples of this on forum as wel.
pratap
Forum|alt.badge.img+12
  • April 12, 2016
Alternatively, you can merge all the data by adding rows for each date then do transpose in one-shot for entire data as shown in below link
https://knowledge.safe.com/articles/1315/advanced-...
Pratap
femo
  • April 13, 2016
I have followed the "vegetable" example in the above link. It works nice. However, if I understood it correctly, it requires knowing the number of records before the script is run to properly feed the attribute creator. I adapted it to my case with , at the Moment, 4 files and it works nice:
The resulting file looks like this:
However, I will have more files to process (by the time of the script run I will not know how many!), each of which will require an additional column with a date value! This seems requireing a loop approach. I tried to dig the "ListPivot.fmx" of the Forum, but I am not successfull.
I played around with the attributepivoter, but it does not bring me any further.
Some more ideas?
  • December 30, 2016
@femo, did you figure out a way to loop this process? I'm trying to do something similar, but I will not know how many date value columns I will need to add. Thanks!
