Hello.. I have a bunch of properties across BC stored as a table in SQL studio where the address fields are null. I don't know how to find the address. I have gdb files of the parcels and have latitude longitude information as well but i do not know to use these to extract the address. Is there any way to be able to do this without any cost. Is there a way to create own geocoder? Any suggestion.?
These are the tables I have. Basically I am looking in to populate these fields.
[PA_ApartSuite] ,[PA_StreetFrom] ,[PA_StreetTo] ,[PA_StreetDir] ,[PA_StreetName] ,[PA_City]
I have around 100K properties to be reverse geocoded. Also the lat long information was extracted using the Assesment Fabric Gdb file shown below.
I also have geodatabase file for all the parcels across BC.. Don't know if it can be put to use in anyway..Also, I do have QGIS but not ArcGIS.
Any help will be much appreciated. Thanks in advance
