MapnikRasterizer:how to rotate a Marker-Symbolizer
  • February 8, 2017
  • 61 views
femo
this time I need to rotate a svg-symbol based on an attributive value. I have set the parameters as
follows:
The parameters in the screenshots for rotation (e.g. 30 degree) and the optional coordinates of the rotation point are hard coded. In the real application they will be filled based on attributes.
Well I get this error:
Invalid Mapnik style configuration. The error was: Failed to parse transform: 'transform="rotate(30,427000,5670000)"
I have tried different Syntax, without success. Do you have any ideas? Maybe the integrated mapnik engine does not support rotation?
Best answer by ebygomm
You don't need the transform = bit
This works for me
Forum|alt.badge.img+46
  • February 8, 2017
This works for me
  • February 9, 2017
Hi @femo, @egomm is right. Just enter your desired value for the 'transform' attribute (SVG specifications) into the 'Transform' parameter field.
Then, you can also enter a string expression with FME general syntax into the parameter field. For example, if feature attributes called 'angle', 'cx', and 'cy' store the angle and center coordinates for the rotation, you can set this expression to the parameter.
rotate(@Value(angle),@Value(cx),@Value(cy))
Additionally, if 'sx' and 'sy' store the scale factors:
scale(@Value(sx),@Value(sy)) rotate(@Value(angle),@Value(cx),@Value(cy))
If you saved the entire transform attribute value - e.g. 'rotate(30,0,0)' as a feature attribute called 'transform' beforehand, this setting would also be possible.
@Value(transform)
and so on. Very flexible :-)
femo
  • February 16, 2017
Hi @takashi and @egomm,
thanks to your help I have solved the issue already some days ago.
The mapnik rasterizer is really very powerfull!
