Best Answer
Transposing part of a simple data table
  • October 26, 2018
  • 32 views
I don't find out how to transpose a part of a simple data table.
I read a lot in the documentation and this kb about the AttributePivoter and AttributeTransposer transformers or other tips and tricks (with AttributeExploder and Aggregator) but I don't get to use these solutions with my test case.
Here is a (simplified) sample of my input data:
And here is what I want as output:
As you can see, the switch has to be done between the "type" and "month" attributes but I have to keep the student column.
I would really appreciate any help because I'm stuck...
Thanks,
Christian
Best answer by takashi
This workflow might help you.
  • October 26, 2018
  • October 26, 2018
Hi Takashi,
You're fantastic !!
I reproduced your solution step by step and I don't really know how, but it works :)
I was very far from the solution so many many thanks !
Now, I try to understand this solution, I have particulair difficulties to understand the AttributeCreator parameters...but I will take time to analyze all this.
Best regards,
Christian
Takashi,
I'm attempting to do a similar transpose with almost the exact same format as the example.
Could you explain why you created two field in the attribute creator, both labeled months?
  • March 1, 2019
Hi @mariofederis, it's just for better understandability and maintainability. This single expression should return the same result.
@Format(%02d,@Evaluate(@Value(_element_index)+5))-2018
