Hello all,
Since updating to FME 2020 (FME(R) 2020.0.1.0 (20200407 - Build 20218 - linux-x64)) the columns filter in the data inspector table view does not work most of the time.
When clicking on the "Columns" button then selecting some columns to display, on clicking "ok" the columns displayed in the table view are filtered to what appears to be a random set of columns. eg. After selecting the following in the column selector:
Clicking ok results in the following columns being displayed in the table view:
As can be seen, they are not the same columns. This happens most of the time, though it does occasionally work correctly. I do not know what is different when it does work. This happens when Data Inspector is opened standalone and also in the Table View in the Visual Preview in Workbench.
This is also occurring in the Windows version of 2020 (FME(R) 2020.0.1.0 (20200407 - Build 20218 - WIN64)). It did not occur when we were using 2019.
Does anyone know what is causing this?
Any help is appreciated.
Thanks
Michael Pascoe
cc: @deanhowell
