I would like to build a floating point raster (geotiff) from a WMS layer. The layer is a LiDAR one and support queries. When I make a query on a single pixel, I can get the floating point value of the pixel, stored in a "GRAY_INDEX" field.
Do you know if there is some with FME to query all pixels within a given extent and build a raster from these values?
Best regards,
Asher
