Right left side of the line
  • January 12, 2020
  • 117 views
boubcher
Forum|alt.badge.img+11
Hello There
I don't know why the point on the same side of the centerline some show left and other show right
I have attached the workspace if some can help to understand this
danilo_fme
Forum|alt.badge.img+53
  • January 12, 2020
Hi @boubcher
I checked that your Source Roads has a micro line - so I used the transformer LineCombiner before the transformer LeftRightSpatialCalculator.
After I did run the Workspace the resultas was correct: all points are Right position - once that the first vertice of line is here:
Workspace:
Thanks,
Danilo
