Create buffers based on Distance and find the count of points within buffer
Hello All,
I have two datasets. The first dataset is excel files that show citizens' residence the second dataset is GTFS. I want to find the number of residents who live within 400 meters from the existing bus stops. I would appreciate the help or advice. Thanks
Best answer by rodrigo_ferrao
Vertex Creator in Residences Lat/Long then connect it in PoinOnAreaOverlayer point entrance.
Vertex creator in Lat/Long of bus stop then geographicbufferer to 400 m then connect it in area entrance of pointonareaoverlayer.
The points will have the Id of the areas (Buffers) and a overlaps of 1 (inside polygon) or 0 (out of buffers). If you have buffer overlapping you may have overlaps greater than 1.
The areas (buffer) will have the amount of points on it in the overlaps field
erik_jan
Forum|alt.badge.img+18
  • May 15, 2018
As far as I an tell from the description, you will need these trasformers:
Bufferer to create the 400 m buffer area
PointOnAreaOverlayer to count the residents in the buffer area.
This is a great site to find the description of the transformers: Transformer Help
  • May 15, 2018
Thank you Erik for the reply. I have applied Buffer transformer on bus stops and then used PointOnAreaOverlayer transformer's area input to Buffer output and Point to residents location. The output does not show the count. It shows overlap 0. Please advise. Thanks
erik_jan
  • May 15, 2018
Are the points actually point objects? And in the same coordinate system as the buffers?
To create points from attributes you can use the VertexCreator transformer.
adriano
  • August 6, 2020
My youtube tutorial on how to buffer points in fme may be helpful to answer this question:
https://youtu.be/UEPgs4a-_zo
