I need to change the order in which features are sent out of an AttributeFilter, because they eventually get set to SQLExecutors which will fail if not processed in the right order (due to database constraints). I have seen questions & answers regarding the port order of custom transformers, but is there a way to control the order in which the features will leave an AttributeFilter? The image shows the situation - the features seem to come out of the InterFeatureLink port first, but they actually have to wait until the features from the RoundPipe port have exited and been executed on the database.
Change order that features leave an AttributeFilter
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
