Identifying T intersection in the street centerline
  • April 11, 2019
  • 61 views
jugoslaviaa
Hello everyone,
I have a street centerline dataset and I would like to identifying where there are T intersection (3 centerlines intersect at same point). Here is the image and I would like to find the highlighted lines.
Thanks in advance.
Best,
Best answer by daveatsafe
Hi @jugoslaviaa,
You can use the TopologyBuilder transformer to create nodes at the intersections. The output nodes will have a list on them with id of the adjoining line and its bearing from the node. The ListElementCounter and a Tester can be used to find the nodes with three lines radiating from them.
danilo_fme
Forum|alt.badge.img+52
  • April 11, 2019
Hi
Please, try to create a point geometry in all Intersection lines - transformer Intersection and after to find relationship between points with 3 lines connected
Thanks
Danilo
daveatsafe
Forum|alt.badge.img+20
  • April 11, 2019
Hi @jugoslaviaa,
danilo_fme
  • April 11, 2019
Hi
Thanks
Danilo
Hi @jugoslaviaa
Just for complement my answer - inside the transformer Intersector there is the option Generate List, please check this option and create a List of elements:
And after this transformer - you can use the transformer ListElementCounter ( like suggest you @daveatsafe ) then the transformer Tester to filter the number of elements that you want = 3.
Thanks,
Danilo
