Deaggregator does not work
  • April 18, 2018
  • 136 views
nmatton
Forum|alt.badge.img+4
Hello,
I trying to convert a fme_aggregate geometry type feature to multiple polygon type features with the deaggregator but the input features remains untouched as ilustrated below
The aggregated features comes from the "Outside" port of the Clipper with "Create aggreate" parameter set to "No" (see below)
I am using FME 2017.1.
Any idea why it is happening ?
Thanks in advance !
  • April 18, 2018
How is the Deaggreator configured?
Have you tried setting mode to "Flatten all levels"?
nmatton
  • April 19, 2018
Oh yes, forgot to check that parameter... Thanks !!
