no path results in ShortestPathFinder
  • August 25, 2017
  • 6 replies
  • 83 views
ronnie.utter
Forum|alt.badge.img+11
I dont understand. I am using the snapping tolerans to 300m. The coordinates in all readers in the template are in EPSG:3006 (TM)
Best answer by erik_jan
HI @sweref.
I made a slight change to the workspace (added a Snapper and adjusted the tolerance a bit) and got all 11 routes.
See attachment for the changed workspace: networkanalyst-mod.fmw
erik_jan
Forum|alt.badge.img+26
  • August 25, 2017
HI @sweref.
  • August 25, 2017
Hi @sweref, the reason is that the road lines don't form a single connected network. All the lines belonging to the same network should touch adjacent line at their end nodes. You have to build a clean network firstly.
  • August 25, 2017
HI @sweref.
Hi @erik_jan, I think the snapping tolerance (500) is too large. It could destroy original shapes of most lines.
erik_jan
  • August 25, 2017
Hi @takashi,
With the original 300 one route was not created. Could need some fine-tuning or cleaning up the network in advance. Concluding: the routes not being created is due to the not connected network as you already mentioned.
ronnie.utter
  • August 25, 2017
thank you for your answer. I Will try to repair the Network. Not at work now. Checking it monday.
thank you. Will try it.
ronnie.utter
  • August 28, 2017
Tried the script. Thank you. I will combine the add of the snapper with Cleaning up the Network.
The thread is solved more or less. Thanks.
