PDF to GeoTIFF
  • September 5, 2018
  • 44 views
Hello,
I have a multiple PDFs that contain image in them self. Image is combination of vectors and some more data that is added later in Acrobat Reader. Beside the image there is the annotation and I would need to crop the image, to remove annotation and after that to mosaic these multiple PDFs.
Is that possible to finish in FME? I've tried RasterMosaicer but it is not working. Also, I have tried Clipper and ImageRasterizer but the result is bad in way that layers from PDF are not good. It disrupts the order of layers and I don't know how to keep it because it is one of the most important things.
This is how it look in PDF and here is how it looks after Clipper and Image Rasterizer.
I have tried to expose the attribute fme_fill_colour but it doesn't change anything.
Hope that I will get some hints. Thank You in advance!
Dejan
xiaomengatsafe
Forum|alt.badge.img+11
Hi @maliodpalube, I think it might help the community better understand your scenario and the issues you are having, if you could share some sample pdf you are working with and the workspace you have so far.
danilo_fme
Forum|alt.badge.img+52
  • October 23, 2018
Hi @maliodpalube
I agree with @XiaomengAtSafe
Is better to send your Source and Workspace to investigate.
Thanks,
Danilo
