XML Templater: how to put list values into one attribute
  • November 10, 2017
  • 33 views
lazarlubomir
Forum|alt.badge.img+10
Hello,
is anybody here, who could help me with XML creating please?
What I have to solve: I have one feature with list of references to another features. I need to create XML record which contains all of these references and also keeps number of reference in Index. Example is below:
I know that I have to use XMLTemplater, I am able to create schema, but I cant identify, how to figure out list values behaviour and also how to insert into index parameter sequenced value from list.
Thank You so much!
Lubo
  • November 10, 2017
Hi @lazarlubomir, this expression might help you.
<Attribute Name="SAF" Class="PDB">{
for $name at $i in fme:get-list-attribute("_list{}")
return <RefObject Index="{$i}" Name="{$name}" />
}</Attribute>
See here to learn more about For Clause in XQuery language: For Clause
lazarlubomir
  • November 10, 2017
}</Attribute>
Briliant answer as everytime! Thank You so much!
