Aggregate and Rearrange Tabular Data
  • July 3, 2017
  • 7 replies
  • 95 views
carmijo
Forum|alt.badge.img+11
Hi All,
I'm attempting to rearrange table A into table B using FME 2017.0.
A
B
I've followed FME's advanced manipulation of tables help, and i can get to this output (below) but i'm having a difficult time getting the premise ID in it's own column and bringing in the additional premise's info.
Any help would be greately appreciated.
Workspace:
Input CSV:
Best answer by ebygomm
I don't have access to 2017 so I cannot see what it is you've done so far, but this workflow does what you need
Forum|alt.badge.img+46
  • July 3, 2017
carmijo
  • July 4, 2017
This works great. However, i'm still having some trouble getting from the aggregator output to a CSV writer. When I view the aggregator output in inspector, the D_% fields are separated as i'd like, but when I attempt to write from aggregator to CSV, the D_% fields are still comma separated and have no values. Of course, this makes sense, but I've tried using an attribute splitter and attribute manager to split out these fields, but I can't seem to get it to work. Any additional help would be much appreciated.
  • July 5, 2017
Possibly you have exposed a comma separated single name like "D_AREA,D_FLAT,D_IMPERV,D_PRCT,D_PRCTIM,D_RESPON"?
Make sure that the AttributeExpose parameters looks like this.
erik_jan
Forum|alt.badge.img+26
  • July 5, 2017
Would the AttributePivoter transformer be of help here?
Sounds like you are creating a pivot table.
carmijo
  • July 5, 2017
That's the first thing that came to mind for me too. It seems like it would, but I haven't gone down that path yet.
  • July 5, 2017
Make sure if the attribute names you have exposed are exactly match the values of "CHAR_TYPE_CD" read from the source CSV. Some CHAR_TYPE_CD values (e.g "D_AREA ") seem to contain trailing spaces.
carmijo
  • July 5, 2017
Haha, of course. Thank you @takashi, that was it.
The three attributes that were missing had trailing spaces in the source data. I used an attribute trimmer after the reader to fix the problem
