Removing parts of a string with the Attributetrimmer?
Hello FME users,
I need to trim parts of a string and have been using the Attribute Trimmer's ReplaceRegEx function. I noticed however that while some fields are trimmed correctly while other's aren't. I have not be able to find a patter or correlation between the length or type of string that isn't trimmed perfectly vs. the ones that are. It looks like this:
@ReplaceRegEx(<|| Toronto>,<|| Scarborough>,<|| Scarborough|| Toronto>,<|| East York>,<|| North York>,<|| York>,<|| Etobicoke>)
The result:
Notice how || Etobicoke is still there. I have tried different Attribute trimmer functions like ReplaceString or TrimLeft and the part I want to keep is sometimes trimmed off.
Would you have any suggestions for a more effective method or this just a bug?
Thanks in advance,
erik_jan
Forum|alt.badge.img+17
  • November 7, 2017
I would use the StringReplacer transformer.
Use the regex [Scarborough|Scarborough|Toronto|East York|North York|York|Etobicoke]
  • November 7, 2017
Or StringPairReplacer
mark2atsafe
Forum|alt.badge.img+43
  • November 7, 2017
So you have the AttributeTrimmer transformer, but where are you using the ReplaceRegex function? Is it inside a text editor for the Trim Characters parameter? If so, I'm surprised this does anything at all. That would be the characters to trim, not a function to carry out the trimming (so whatever is trimmed inside that editor dialog, the result is what is used to trim the Attributes to Trim).
Or am I reading that wrong? Can you post a screenshot of the AttributeTrimmer parameters?
In general you could use the AttributeManager instead and put your function inside the text editor. I think that would work. Or - as others suggest - try the StringReplacer in regex mode.
mark2atsafe
  • November 7, 2017
nb: if you are using the AttributeTrimmer transformer the Trim Characters parameter is exactly that, a list of characters to trim. It's not a substring to be removed. So if the "Kingston Rd" part is not being trimmed, it's only because the letter "d" isn't part of the character list. Otherwise that would be chopped too. That makes me wonder if you are using the AttributeTrimmer transformer or not.
Forum|alt.badge.img+19
  • November 7, 2017
What is the original string, and what part(s) should be removed (trimmed) from that?
  • November 8, 2017
Hello Mark2AtSafe,
I am trying to trim only the "|| (city)" portion of the string using the AttributeTrimmer transformer. I posted this because my method is working for the most part but not perfectly ( as per my original post the "|| Etobicoke" is still there..
erik_jan
  • November 8, 2017
I have created a sample workspace (see attachment) that will remove the || City.
You regex should be \\|\\| (Scarborough|Scarborough|Toronto|East York|North York|York|Etobicoke).
city-remover.fmw
mark2atsafe
  • November 8, 2017
1011analyst wrote:
Hello Mark2AtSafe,
Right, then you should definitely NOT be using the AttributeTrimmer. The ReplaceRegEx function might be fine in an AttributeManager, but not here. That field is just a list of characters to remove/trim. It will trim past the || part in your source string if you have characters that match. So try either the StringReplacer or an AttributeManager, but not the AttributeTrimmer.
I'll ask for a documentation update so that parameter in the AttributeTrimmer is clearer.
  • November 8, 2017
@Mark2AtSafe
Thanks
  • November 9, 2017
city-remover.fmw
Thanks @erik_jan,
This has worked for me except for the double city parts of the string e.g. (|| York||Toronto). Where only the "(|| York)" was removed and the (||Toronto) is still present. I fixed this by outputting the file and re-running the original RegEx with the last portion e.g.||Toronto, on the new file. Would you be able to recommend a more automated option?
erik_jan
  • November 9, 2017
1011analyst wrote:
Thanks @erik_jan,
I think changing the regex to:
(\\|\\| (Scarborough|Toronto|East York|North York|York|Etobicoke))*
will remove multiple city entries.
  • November 9, 2017
1011analyst wrote:
Thanks @erik_jan,
Perhaps the reason is that there isn't a space between '||' and 'Toronto'. The regex @erik_jan provided matches the string part only if there is a single space between '||' and city name. If there could be cases where there isn't a space, modify the regex like this.
\|\|\s*(Scarborough|Scarborough|Toronto|East York|North York|York|Etobicoke)
  • November 9, 2017
If you just want to remove the trailing part starting with ||, this expression could also be available.
@ReplaceRegEx(@Value(SERVICE REQUEST LOCATION),\s*\|\|.*$,"")
