?reating geometry along lines
  • January 10, 2020
  • 20 views
muzhnasto
Forum|alt.badge.img+12
I have a polyline where each point has its own height
for these polylines I need to recreate the geometry (a pipe is round with a diameter of attributes, a pipe is rectangular with different ratios of width and height from attributes)
but difficulties appeared
the pipe has fillets at the end
and pipes of square section are either built on a plane or along non-joined segments
Friends I ask for help on how to build a solid geometry, taking into account different heights, and make the end of the pipe flat
daveatsafe
Forum|alt.badge.img+20
  • January 10, 2020
Hi @muzhnasto,
You may want to try the Hub3DBufferer transformer instead. It is not as fast as the Bufferer in True Solids mode, but it will produce flush ends on the pipes. It won't do square sections, however.
muzhnasto
  • January 13, 2020
Hi @muzhnasto,
Hi daveatsafe Hub3DBufferer transformer creates pipes with smooth ends :) ,
did not find a quick way how to make solid with fewer polygons in geometry, It does not make square sections :(
Anyway thanks for the help :))
daveatsafe
  • January 13, 2020
Hi @muzhnasto,
I modified the transformer once to create square sections, but can't find that version now. Since it is a custom transformer, you can modify it yourself, although it is a bit complex. I did document all the sections for clarity. I would look at the GeometryReplacer inside the transformer first.
muzhnasto
  • January 15, 2020
Friends, can anyone else have suggestions
