Written raster cell values different to inspector
  • February 15, 2016
  • 33 views
Hello,
I'm experiencing some issues with the raster outputs of my workbench. I have the same issue in FME 2016.0.0.0 and 2015.1.2.0.
I am converting several vector files to raster and I am then adding them together to perform some analysis. However, in the output raster negative values, including the No Data value, have been written as the cell value 3.
I have sent the output to a data inspector before the writing stage and the values are correct. I have attached some images below to show the differences
Values from pre-writer stage:
Values from output:
Does anybody have any ideas on how to get the values to write correctly?
I noticed that the output is a 2 bit image and I used a RasterInterpretationCoercer to set it to an 8 bit integer but it still created this 2 bit image with incorrect values.
Thanks in advance
jdh
Forum|alt.badge.img+40
  • February 15, 2016
What format is your output data? Is it a format that supports 8-bit signed data?
  • February 15, 2016
I'm writing to a geotiff.
I noticed there is parameter in the writer to set the number of bits per cell.
I set that to 8 but it is still creating a 2 bit output
jdh
  • February 15, 2016
If you leave that blank, it should pickup the bit-depth of the raster.
If that doesn't work try writing the data to FFS instead of geotiff and sharing a sample here.
