How to identify polygons that intersect and or overlap each other and collect the feature attribution from the overlaps?
  • February 15, 2016
  • 28 views
ngstoke
I have 2 polygon shapefiles. I want to identify polygons (A,B,C.... labeled in JPG) that intersect with another set of polygons (Abstract #1, #2, #3,#4). Once the Abstract polygons that intersect are identified, I'd like to merge just the attributions from these into the A,B,C polygons.
I'm attempting to use the SpatialRelator but I'm having difficulties.
Single Shapfile with this attribution:
Polygon A ---(Abstract 1,2,3,4)
Polygon B---(Abstract 1,2,4)
Thanks in advance
erik_jan
Forum|alt.badge.img+17
  • February 16, 2016
AreaonAreaOverlayer is the transformer that you want to use.
It will merge the attributes and clip if the polygons overlap partly.
erik_jan
  • February 16, 2016
And if you do not want to Clip the polygons, the SpatialFilter transformer can be used.
mark2atsafe
Forum|alt.badge.img+43
  • February 16, 2016
I'd try a different test, just to prove that it is working. Also, I wonder if there are aggregate features there? Try putting a Deaggregator transformer before the SpatialRelator?
