Best Answer
How to split geometrically seperate PointCloud parts
  • August 2, 2019
  • 33 views
mhab
Forum|alt.badge.img+10
I use a PointCloudFilter where I try to find the lowest parts in a PointCloud.
In this way I get two long straight stretches of PointCloud remainders, which are clearly seperate and quite far from each other (i.e. >10 times the distance of points in the Pointcloud).
My problem now is how to split up those different parts/groups of the same PointCloud so I can use each remainder independently ?
PointCloudCoercer -> "Single Multipoint" + HullReplacer doesn't give me different parts.
I could not find other ways to tile/split PointClouds in the way I need.
Any ideas ?
Best answer by klaas
Hi Michael,
What you could do, is the following:
1. Export the remainder(s) as single points
2. Use a TINGenerator (tolerance = 0)
3. Remove the Edges longer than -let's say- 2 times the point distance
4. Perform a NetworkTopologyCalculator
5. Then use a TINGenerator again (Group By _network_id) and use the Vertex Points
6. If needed, rework the point features into pointclouds (Group By _network_id)
BTW, the mentioned process will remove points with the same x-y coordinates.
Hope this helps,
Klaas Dijkstra
klaas
Forum|alt.badge.img+12
  • August 3, 2019
Hi Michael,
Hope this helps,
Klaas Dijkstra
mhab
  • August 3, 2019
Hi Michael,
Hope this helps,
Klaas Dijkstra
Thanks for the inspiration. Long way to go ...
klaas
  • August 4, 2019
The way is shorter, actually: step 1. is not needed. The TINGenerator accepts point clouds.
Good luck anyway.
