download multiple zip files from url
pat_uow
Hi all,
I'm trying to download all zip files from the URL below, keep a copy of the zip in one local folder, and a copy of the extracted csv in another local folder.
http://www.nemweb.com.au/REPORTS/CURRENT/Daily_Reports/
Using the workspace attached , I can successfully download and extract a single zip file and csv content.
I believe there may be a list of all zip files available from the URL hidden somewhere in the response, but how would I go about extracting all available zip files and storing the resulting csv ?
Thanks
Forum|alt.badge.img+49
I've used a StringSearcher after the HTTPCaller with this regex to look for the (partial) urls:
/REPORTS/CURRENT/Daily_Reports/PUBLIC_DAILY_\d+_\d+.zip
Set it to generate a list and you'll end up with a partial url for every zip file referenced on the page. From there you can explode the list and download them one by one.
arnovananrooij
Forum|alt.badge.img+5
You could use a HTTPCaller and a HTMLExtracter to get a list of all the Files. After this you can use the ZipExtracter to download the files I think.
