split line at point , whic transformer is equle to ArcGIS "split line at point"
  • November 22, 2017
  • 355 views
esaka
Participant
Best answer by fmelizard
Hi @esaka.
Please look into the PointOnLineOverlayer https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/pointonlineoverlayer.htm
fmelizard
Forum|alt.badge.img+21
  • November 22, 2017
esaka
Participant
  • Participant
  • November 23, 2017
Hi Natalie
Thankyou, in some way or another I overlooked this function because I used to use this transformer if required.
arash_hokm
Forum|alt.badge.img+8
  • August 12, 2022
I have exactly this problem but I don't know how can I use PointonLineOverlay as a split the line
evieatsafe
  • August 15, 2022
Hi @arash_hokm​ if you have points near or on your line you can use them to split your line with the PointOnLineOverlayer. I've uploaded an example workspace that has both lines and points and shows you that with a tolerance of 0 it will split the line at the point intersection with the line.
If you have any questions in the future, we suggest that you create your own post instead of commenting on an old one as there will be more visibility.
I hope this helps!
