excel sheet - copy a row based on a value to another sheet
  • July 15, 2019
  • 58 views
kevink
Forum|alt.badge.img+3
hello,
i have a excel document that i want to change with fme.
What i want is that colum A, B, C, D and E are copieed to another file if there is a value in a certain date (of colum F........till...AC)
Here is the result that a want: U will see that a want that a row will be copieed if there are more values of a diffrent month, see row 20 and 21.
i hope that u understand it, the document of excel is attached
stalknecht
Forum|alt.badge.img+22
  • July 18, 2019
xlsxr2none.fmwt
Here is an example in FME 2019 using an inlineQuerier.
Good luck!
kevink
  • July 22, 2019
Thanks for the response, i wil try the inlineQuerier.
kevink
  • July 24, 2019
it worked perfect thanks!
i also add a cloner to split a row on a value (higher then 1), so u get multiple rows of the value is bigger then 1
