Help replacing this bloc of transformers with a shorter one
  • October 12, 2018
  • 26 views
Hello,
I am working on input datasets having different schemas. In the end of my translation, I have to inspect obtained results. I had therefore to use a testfilter and 3 (AttributeManagers + Inspectors) as shown in the screenshot. The attributes managers perform some schema mapping depending on input features (this include removing and adding attributes)
Is there a way to reduce the amount of used Attribute managers and Inspectors ? My workspace is getting really big and I need to optimize it.
Thank you very much.
Best answer by redgeographics
Depending on exactly what you do in the AttributeManagers you might get away with replacing all 3 and the TestFilter with a single AttributeManager and make use of conditional statements (basically a Testfilter inside the AttributeManager). That might be a beast to set up and maintain though.
Perhaps a SchemaMapper could be useful too, again it depends on what you're doing exactly.
  • October 12, 2018
If you need to visually simplify the workspace, there are two simple solutions:
  1. Collapsing bookmarks, introduced in FME 2018
  2. Custom transformer
They both have their advantages and disadvantages, so be sure to skim through the docs before committing to either.
Forum|alt.badge.img+62
  • October 12, 2018
fmelizard
Forum|alt.badge.img+21
  • October 16, 2018
SchemaMapper would definitely move the complexity of the renaming out into an external Excel or CSV file. And you'd have only a couple transformers as your reward. A set of tutorials (this thing is powerful) starts at https://knowledge.safe.com/articles/1136/schemamapper-transformer-tutorial.html
