Merge small polygon with larger container polygon
  • July 24, 2019
  • 12 replies
  • 184 views
I have set of polygons representing streets like in the image below. I want to merge small polygons like the selected orange polygon to their bigger container polygon.
I do not know how to do this with FME. What would be a good approach?
Thanks for any help!
  • July 24, 2019
Have you looked at the Dissolver?
  • July 24, 2019
Hi @oiram, if I understand the requirement correctly, this workflow does the trick.
  • July 24, 2019
Yes, thanks.
  • July 24, 2019
Excellent, this works nicely.
However, I would prefer that the larger streets "win" over the small. Now, the small streets reach into the larger ones. Is there a way to control this?
Thanks!
  • July 24, 2019
Thanks!
I'm unclear exact situation of the original dataset. Is a small polygon (red) within an overlapping area of two large polygons (blue), like this?
  • July 25, 2019
No, the small polygon is on the borders , like the green square. It's created by an AreaOnArea overlay of the two streets which have an overlay in the original dataset. In the solution above, the green square becomes part of the vertical polygon and the horizontal is cut out (clipped) in this area. I would like it to be part of the horizontal, bigger blue polygon, so that both are still rectangles in this example.
  • July 25, 2019
Thanks!
OK. After calculating the area for every original polygons with the AreaCalculator, you can achieve the goal with this workflow including the AreaOnAreaOverlayer.
  • July 25, 2019
Excellent, this works perfectly.
One last question: Is it possible to sort on the list based on two attributes? Meaning, if the first criteria to sort is equal on two attributes, take a second to rank them?
featureattribute Aattribute BrankA1081B1052
Forum|alt.badge.img+46
  • July 25, 2019
Unfortunately, the list sorter doesn't currently allow sorting by multiple attributes
  • July 25, 2019
Ok, thanks for the information.
  • July 25, 2019
It is possible to sort the list in fme using python
  • July 25, 2019
You can use the Sorter instead.
