XML Templater Grouping
  • September 10, 2019
  • 55 views
deanhowell
Forum|alt.badge.img+24
Hello all,
I am trying to create an XML file that has a structure where there is a single plan, non-spatial, that has one or more polygon features(parcels). Each polygon feature is made up of multiple line which in turn is made up of multiple points.
The plan is a database table without any geometry so I have done a feature merge using the bounding box of the parcels. I then chop the parcels into points and lines and feed the three outputs into the XML templater, using the plan as the root feature.
What I am trying to acheive is the following
Plan
Parcel 1
Line 1
Line 2
Line 3
Line 4
Parcel 2
Line 5
Line 6
Line 7
Line 8
Point 1
Point 2
Point n
but what is coming out is a list of all lines rather than just the lines for the individual parcel.
Plan
Parcel 1
Line 1
Line 2
Line 3
Line 4
Line 5
Line 6
Line 7
Line 8
Parcel 2
Line 1
Line 2
Line 3
Line 4
Line 5
Line 6
Line 7
Line 8
Line 5
Line 6
Line 7
Line 8
Point 1
Point 2
Point n
I have tried grouping but that then seems to have affects on other features.
Attached is my XML workspace.
Any tips would be greatly appreciated.
Regards
Dean
Hi @deanhowell, if "parcelid" is unique ID for each parcel and lines derived from a parcel have the same "parcelid", this expression groups lines by "parcelid".
    <lines>
    {fme:process-features("LINES", "parcelid", fme:get-attribute("parcelid"))}
    </lines>
See here to learn more how to use the "fme:process-features": XQuery Functions
deanhowell
    <lines>
    </lines>
Thanks @takashi, that worked a treat. I must have tried a hundred variations yesterday :) thanks again.
