Inaccurate reverse geocoding (using HERE geocoder) >1km off
Hi all,
I'm having issues working with the Geocoder transformer.
I'm using the HERE geocoding service to reverse geocode : e.g. 51.9237996084706, 4.486035956925605
The result shown in the Data Inspector show:
51.9161, 4.4784 - which is about 1km off.
How can I fix this?
Thanks,
Ed
Best answer by nathanatsafe
Hi @edhere, @Mark2AtSafe and others,
This issue is on my radar and I just wanted to follow up a bit.
After some investigating, we've found that the search radius parameter (HERE documentation) accounts for the difference between the two results. Our request through the Geocoder is something like this, while something like this is needed to obtain your results.
In light of some overhauls to the Geocoder for 2018, it looks like we can incorporate the radius parameter going forward, and we expect to have this functionality ready sometime around 2018.1. I'll be happy to post here on any further developments, and be sure to let me know if there are any further questions or concerns about this issue.
Best,
Nathan
Forum|alt.badge.img+49
Could you also post the Geocoder settings?
I would imagine a specific address coming out of it rather than this general "city centre", does this happen with all coordinates you try or just this one? Could it be a limitation of the HERE geocoding service?
  • June 30, 2017
@redgeographics
Hi, the image should be working now.
The settings I'm using:
I'm having the same issues with other sets of coordinates, the difference between input latlongs and output varies between 300m - 1000m.
When I put in the same coordinates in the HERE reverse geocoder API I do get the correct results back:
Cheers,
Ed
  • July 4, 2017
Are there any SAFE people able to help me out with this issue?
Thanks,
Ed
  • July 4, 2017
Just an idea, but you could use something like Fiddler to inspect the calls FME makes to the Bing geocoder to verify what's going on behind the scenes. That might help you see if it's a problem with FME or with Bing.
mark2atsafe
Forum|alt.badge.img+44
Hi @edhere
I'll have our developer take a look at this.
If I have it correct, you are reverse-geocoding 51.9237996084706, 4.486035956925605
Using FME+HERE it returns 51.9161, 4.4784
Using the HERE API directly returns 51.9238, 4.48604
There are limitations with HERE's reverse geocoding in that it only resolves down to the 'district' and only returns 5 decimal places of precision, but it doesn't seem to be the issue here. I'll check into it and get back to you as soon as I can.
Regards
Mark
  • July 5, 2017
mark2atsafe wrote:
Hi @edhere
Regards
Mark
Hi @Mark2AtSafe
Yes, those are the correct values mentioned.
Thanks for taking a look!
Best,
Ed
nathanatsafe
Forum|alt.badge.img+7
  • February 15, 2018
Best,
Nathan
  • February 16, 2018
Best,
Nathan
Hey @NathanAtSafe,
Thanks for looking into this issue and following up.
Please keep me posted on this.
Best regards,
Ed
  • April 20, 2018
Best,
Nathan
Hi @NathanAtSafe / @Mark2AtSafe
I've downloaded the 2018.1.0.0 beta and decided to go back and have a look.
Using the Geocoder an leaving the Radius (m) field empty results in the incorrect location.
With the Radius (m) field set to 20 the Geocoder returns the proper address: Meent 20 in Rotterdam.
It seems it the issue is fixed!
Best regards,
Eduard
nathanatsafe
Best regards,
Eduard
That's great news @edhere! It looks like the fix passed our quality control mid-March and it has made its way into the latest builds. Please keep us informed of any further issues you might run into with our HERE Geocoding.
Best,
Nathan
